Homelink buttons on rear view mirror
itsaguything
Manotick, On, Canada
Greetings All!
I will be posting on a few forums as I’m not certain we have the same readership on each.
The homelink buttons on the rear view mirror of the LR2 do not operate at all. No flashing led whatsoever, no matter what the operation.
Furthermore, the garage door does not even recognize any signal from only my LR2.
I have been all through the Owners Manual. I cannot find any reference to the appropriate fuse.
I have been through the electrical guide…. but it is the guide for the earlier version of lr2 and there are so many differences.
I have also tried the age old sledge hammer fix of a proper system reset.
All to no avail. Does anyone have any ideas?
Thanks.
Cheers!
Rover Range
Texas
There is a fuse, FP 12 in the fuse box behind the glove box. If the fuse is good, the mirror will need to be replaced.
itsaguything
oh…. “mirror control” = “homelink buttons”. And being that the reverse lights work…. Looks like I’m buying a mirror.
Thanks @Range\ Rover!
BigBriDogGuy
Bellingham, WA (USA)
This may sound stupid (and probably is) but have you tried pushing and holding down two buttons at the same time (outside right and outside left, I think)? Been a minute since I set mine up (successfully after a number of different runs at it). Seem to recall the entire library of saved signals gets wiped for reprogramming to a new garage door if you hold down two of the buttons. But you have to hold them down at the same time and keep them pressed for 5-10 seconds and then the light starts flashing.
Spit balling here and probably not what you are dealing with, but in the off chance the entire system got wiped somehow, maybe attempting a hard reset it would get it up and running enough that you would have something to work with.
