THATE30GUY
- Joined
- Nov 29, 2015
- Posts
- 3
- Reaction score
- 0
Hello -
Looking for some help with a 2004 Discovery 2 that will not start.
I had a broken timing chain cover seal, and decided to take on the challenge at home. Went through the whole exercise, and while I was in there replaced the Oil Pump Gears and Timing Chain Trio. After re-assembly, I put oil in the motor and turned the motor on. It ran (very roughly) for about 15/20 seconds, and then the motor shut off.
Since then, the motor will turn over- But it will not run.
Since then, here is what i have done:
I pushed the top of the Inertia switch down. (Did not click)
I checked the fuel pump (and replaced with a used one). Even the new fuel pump does not seem to be running (there is no real sound coming from it when the key is turned). That being said, there is some pressure in the line. After turning the engine over a few times, I pulled the fuel line and got a surprise.
Checked fuel relays and fuses. All looked good.
Checked for spark. Sounds like i may have done this wrong. I pulled a plug and watched for a spark. There is spark (which makes me think this is not a CPS issue). But I'm not sure if i messed something else up by turning the engine without a plug in the hole.
Also shot some carb cleaner in the intake while cranking. I took the elbow off of the intake manifold and sprayed while the motor turned over. This caused a "POP" and the carb mist to ignite at the intake.
From here I am completely lost. I do not have a code reader, but am thinking that I might need to buy one.
It seems like there is an issue with fuel delivery, but being new to the Disco I am not sure how to test it. A part of me is afraid that the timing is off, but i was very careful to follow the instructions in the manual (line up the dots, remove the old, install the new and make sure the new dots align).
Does anyone have any thoughts on what might be going on? Could the CPS be bad but still have spark at the plug?
Thanks in advance for any help.
