Burner6999
- Joined
- May 25, 2014
- Posts
- 5
- Reaction score
- 0
I have been having issues with my SatNav. It never saves the settings for anything. I had an issue with the alternator, but have since replaced it and have had no other problems besides the nav settings. It doesn't save anything. I change the view and the region and store waypoints and it all goes back to default on next start up. I have had my LR3 for about a year and it has always done this since I have owned it. Any ideas why it does this? Thanks in advance.
Tried the hard reset and it didn't change anything. It is weird because it has saved my home address and one of my marked points, but nothing else ever saves. If I change anything or add marked points it loses all the changes and reverts back to default settings and keeps only my home address and my one marked point from months ago.
Edit:Ok well I have some more information. It is saving my memory points just not where I saved them. I change the category names and they get reset. So it moves them to a different category. I took out the TSD and the Nav system under the seat. I check the plugs and saw no loose wires checked the voltages and they all seem good. The settings for the TSD stay. I also download some newer maps from Europe (Ilive in the USA) just to see if the software update would fix it and it didn't. I didn't want to pay $200 if I can fix this problem. I think it is either the ground or the 12v Batt wire that may be the problem. Any advice about other grounds to check or places to check them?
