03discolover
- Joined
- Oct 28, 2014
- Posts
- 5
- Reaction score
- 0
i drive an 03 SE with 130k
hello! i'm sure millions of these threads have gone through, but i'm going to try just like the others. I've already done the following:
replaced lifters
new oil pump (pressures are fine already have done four readings)
no coolant in engine
no drips off the bottom of the car
no check engine
no noticeable fluid drain from reservoirs except ACE (to hell with it at this point)
no hiss when removing oil cap like some reported
when i start the car cold sure there's no tap. but it gets interesting after:
once it's heated up, it will tap sometimes, then not others.
-sometimes when i put it from park into reverse or drive, it will go from not tapping to tapping
-if it's in drive sometimes it won't be tapping, but the second i give it the gas it'll start tapping
-sometimes it just wont tap at all
-sometimes it'll tap at half the normal tapping speed, as if sometimes it misses whatever it's hitting
-sometimes it just taps consistently
as i've ruled out a lot of tests that usually can corner the problem, I'm still baffled. maybe check out rocker arms? or possible that it's an exhaust leak? sometimes when I start it cold it sounds a little metallic, maybe it's that. I still have yet to install a 180 temp tstat so maybe I should try that too.
replaced lifters
no check engine
