04 Turnsignal Issue
FrankZ
Front-Left turn signal flashing rapidly, rear not flashing at all. Tried replacing the front (dual filament) bulb and the rear (single filament) with no effect.
Hoping for a few tips before I start ripping out wiring....and my hair.
Any common/well-known problem areas to focus on?
If the front is flashing fast and the rear is not, then you have a bad bulb in the rear or a bad contact, start by checking the plug and wiring if you have already changed the bulb. Check for corrosion, might just need to clean the contacts.
sawcut
