Go Back   Land Rover and Range Rover Forums > Technical Discussions > LR3
Sponsored Ads
Register or log in to remove these ads.
LR3 technical discussions for the LR3
Reply
Thread Tools
Old 09-13-2007, 07:15 PM   #1
sunlion
Landy Man
Back Up sensors - erratic?
Has anyone else noticed erratic behavior with these sensors? They do not engage every time the truck is put in reverse. I've had the dealer look into it and they said it functioned properly. It seems that a sequence of steps needs to be followed for the sensors to turn on, namely step on the brake, move from P to R then manually release the parking brake. It often does no engage going from D to P or if the gas pedal is pressed to disengage the ebrake. I have had not one but two encounters with my brother's mail box because of this, the last of which left a nice dent in my lower tailgate.
sunlion is offline   Reply With Quote
Old 09-14-2007, 09:27 AM   #2
schafari
Erratic and ultimately failing backup sensors is not completely uncommon. IIRC, there is a speaker relaated failure and a control unit failure. Regardless, anytime you move into reverse, the sensors should activate. If they don't, there is a problem. If you don't get the "I'm on" chime when you move the gear shift to reverse, there is a problem. Look at the button, is it flashing or steady? If it is flashing, that indicates a failure. If you have intermitent problems, has the sound of the beep or chime changed? That would indicate eventual failure likely.
(Not to be a jerk. . .but do you really depend on the sensors to gaurantee you don't hit anything while backin? If they don't warn you. . .you proceed to back into a mailbox. . . twice? As a father of three very small children that may or may not set off the sensors. . .this scrares me to no end. . .)
schafari is offline   Reply With Quote
Old 09-14-2007, 10:56 AM   #3
grommet
sunlion, what year? The logic has changed twice. The 2nd version just turns on when you drive very slowly. The original version only activates when you do a specific park/reverse manuever. For the 3rd version (default on 2007+), it's back closer to the original logic... since people complained the 2nd version activated too much by stray noise.
At least on the 3rd version, you can press the button to force an activation. (The button will light to confirm.)
grommet is offline   Reply With Quote
Old 09-16-2007, 03:30 PM   #4
sunlion
Landy Man
My LR3 is 2005. I don't depend on the sensors alone but they should pick up things below the view of the tailgate. I have a lot of small children around also and I make sure none are anywhere close when I'm backing up.
Old 09-16-2007, 07:33 PM   #5
grommet
If you have a 2005, the PDC can be upgraded to the improved logic. (Via module replacement.) There is a TSB article for 2005 about the PDC not activating all the time; just take it in with this specific complaint. If you are still in warranty, you'll be fine. I'm not sure if you'll get the 2nd or 3rd version of the logic now... either one will be better than the 1st flawed implementation.
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Sponsor Ads
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
Fully Driven Auto Network
GM Truck Forum
Chevy Tahoe Forum
Dodge Ram Forum
Chevy Cobalt Forum
Chevy Tahoe Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Ford Raptor Forum
Scion FR-S Forum
Softball Forum
TRD Forum
Central US Mopars
Southeast Mopars
Cadillac CTS Forum
Oklahoma Dodge Ram Club
Softball Forum
