2007 LR3 HSE, black/tan, many mods for camping and exploring, $29,000
jwest
Seattle WA
Selling my 07 LR3 HSE with lots of extra stuff on it for offroad and camping:
$29k not $32k
2007 LR3 HSE, Metallic Black w/ Tan interior fully loaded with LUX, SAT, NAV and HSE pkgs. *Metallic Black is the one color Land Rover applies in extra coatings for longer life and durability.
photos: http://www.jwestproductions.com/2007LR3/
50,000 miles as of December 2010
*warranty can be extended by dealer. For example, the one offered by Land Rover Cary NC dealer, Issued by Republic, Platinum level +3yr/100,000 mile ~$4375 +4yr/100k~$5100
This is totally "set up" for serious trail and/or camping use (parts list below) but it has not been used very heavily. It was a project to fulfill and idea and has since been replaced with something more appropriate for our needs.
All standard services have been done by Rover dealer.
The body is perfect, the leather is clean with no damage anywhere (2nd and 3rd row seats have been folded closed and covered by rubber mat 100% of the time anyway keeping them perfect.
(All roof items like Rack and awnings in photos not part of sale however wiring for roof lights stays with vehicle to use as desired by new owner. There are a total of 6 plugs with 2 being for the rear. All are on 4 separate switches up front in the roof) (Rack and awnings in photos not part of sale however I can direct you to the same source to make it easy if interested in same things) Even without the roof rack and lights, the wiring and interior switches will remain for very simple set up of your own layout. 4 switches total, 1 controls both rear lamps, 3 control L,R, middle front or side lamps.
The leather is clean with no damage anywhere (2nd and 3rd row seats have mostly been folded close and covered by rubber mat 100% of the time anyway keeping them perfect.
Window tinting is 3M all including sunroof, legal in all states at more than 35%
MODS/PARTS (rough initial costs including shipping/tax):
$1300 ARB bumper - with factory fogs and parking sensors re-installed (one fog lens cover is cracked but functioning 100%)
$1000 WARN winch XD9000
$250 Hella 1000 black magic lamps on bumper with clear plastic stone shields
$1500 Rasta underbody plating (all 4 sections available for lr3 including radiator guards too)
$1600 Rock Sliders/undersill side protection plating with side rails by Rover Specialties (very protective of the air tank and compressor as well)
$2400 Rear bumper/tire carrier/jerry can holder by KAYMAR with parking sensors re-installed and license plate relocation with lamp. Tire carrier was relocated more toward middle of car to allow better visibility of right rear tail lamps.
$800 Could include custom bike hitch style mount and bike rack for hitch mounted bike racks - this keeps rack high from ground and not using the actual hitch.
$300 rear ladder-lr genuine
$250 rear lamp guards-lr genuine
$80 body side moulding-lr genuine
$550 snorkle-lr genuine
$350 towing block and wiring-lr genuine
(?$ Prodigy brake controller is set up too)
$300 cargo mats rubber-lr genuine (rear flat, rear 5" deep, 3rd row foot-well, other passenger as well)
Electrical & AIR (run on 2nd battery system-all switches, gauges inside left rear access panel):
$500 DUAL BATTERY system user switchable from either to combined using Odyssey 2150 custom mounted in enlarged normal location (almost double capacity of yellow top optima).
$100POWER INVERTER flush mounted in left rear panel wall
$500 ON BOARD AIR socket fed by ARB compressor mounted on right side vehicle with stock 2nd air tank similar to left side arrangement (both protected by rock slider plating)
3x 12V SOCKETS additionally mounted 1 at each very rear panel top and one near left side 2nd seat door panel section for Fridge, etc.
MAP LIGHTS & secondary DOME LIGHTS all run off 2nd battery, center dome lights run standard with normal stock time-out feature)
$400 Rear work lamps and/or forward roof lights - switchable via 4 lit switches in front cockpit overhead.* roof rack and lamps *not included *but it is all pre-wired (no roof holes were cut, all are powered through single line out the back hatch with single plug for roof rack removal simplicity)
Parts alone were over $12k, all work was done by a 20yr certified Master Land Rover tech in NC at Flying Circus English Cars, Ltd. Labor was roughly $10k
Stock 19" wheels also available in addition to stock bumpers and sills depending on sale price.
Note: 5 spoke wheels shown are not on car. Have been replaced with 2007 SE 18" version which are the second generation of the 10 spoke design, not the 05-06 flat 10 spoke but the flutted spoke style found on SE in 07-08 seen in snowy photo and rear photo.
**Stock bumpers and sills can be shipped to buyer at their cost.
jwest
Seattle WA
morrisdl
Cool Rig! Good luck with the sale! I hope it goes to someone that appreciates it in the wilderness (and not the mall parking lot). Whats the next project?
Slam
Supporting Member
Supporting Member
Wow. Very nice rover.
MHS
Hi,
Is this LR3 still for sale? Do you have additional pictures of the interior & exterior from all angles? Do you have a CarFax? Where are you located? What is the current price? Please PM me if you do not want to post here.
Thanks,
Matt
P.S.: I sent you a PM as well with my contact info, I look forward to hearing from you soon!
