Go Back   Land Rover and Range Rover Forums > Technical Discussions > Discovery
Sponsored Ads
Register or log in to remove these ads.
Discovery technical discussions for the Discovery
Reply
Thread Tools
Old 06-23-2005, 12:02 AM   #1
charvey
Posts: n/a
discovery 97 and OBDII
Has anyone hooked up an OBDII scanner or linked a laptop via a connector to a Discovery 1997? I have spent quite a bit of time looking at OBDII information and believe it could tell me which one of my wheel speed sensors are failing (ABS comes on after the vehicle has been inactive for a while, mostly at slow speeds.)
The problem is that none of the protocols I see listed for the connector match my pin setup - my Discovery seems to have pins in the ODB2 connector at positions 1,2,4,9,10,12, and 13. This matches none of the protocols that are described below:
PWM The connector must have pins 2, 4, 5, 10, and 16
VPW The connector must have pins 2, 4, 5, and 16, but not 10.
ISO The connector must have pins 4, 5, 7, and 16. Pin 15 may or may not be present.
CAN The connector must have pins 4, 5, 6, 14, and 16.
The ODBII laws say that all vehicles sold in the US after 1996 have to be ODB2 compliant - is the Discovery simply a different protocol, is it not compliant, or am I missing something?
The only other thing I can think of is that I may not have been looking at the correct connector - but the connector I found was under the right hand side of the steering wheel, out in the open, was 16 pin, and looked right...
Any help is greatly appreciated - I'm a new owner, love my Discovery, and just fixed the cruise control tonight based on info I found in this forum :)
Thanks much,
Charles Harvey
Old 06-23-2005, 01:18 PM   #2
RoverDisco98
Posts: n/a
Not sure there is a difference between 97 and 98 but I took my 98n to AutoZone and thet simply plugged in the reader and gave me the codes.
Old 06-23-2005, 07:15 PM   #3
charvey
Posts: n/a
I'll give that a try - I was hoping to use Scan Tool because it lets you communicate to your vehicle in the ODBII language (give commands and make adjustments).
I should be able to find out what interface Auto Zone is using.
Thanks much,
Charles
Old 06-26-2005, 04:15 AM   #4
Jeff Discos
Jeff Discos's Avatar
I don't believe my OBDII reader (laptop operated) shows any data at all on the ABS system.
__________________
Me: So-and-so mechanic shop said the work would take them 5 hours.
The gf: That means it will take you a lot longer than 5 hours, right?
Me: That's not very nice.
Jeff Discos is offline   Reply With Quote
Old 05-29-2010, 09:36 PM   #5
chicken little
Roverito
Hi all,
My Discovery I has started missing, more and more over the last 5000 miles... can't really figure it out. Replaced the plugs & wire set... very little improvement, itf any. Can anyone
let me know some common reasons for missing, backfiring? Most obvious during acceleration, and under load (hill climbing), however pretty consistent at all speeds.
I just don't want to start randomly replacing parts. Thanks!
chicken little is offline   Reply With Quote
Old 05-30-2010, 07:51 AM   #6
vegas99d1
Landy Man
Chicken - what kind of gas are you running? Also, when is the last time you changed your fuel filter?
__________________
Keep Austin Weird!!
99D1 SD
245/75R-16 BFG AT's
Soon to have 2" RTE spring lift
vegas99d1 is offline   Reply With Quote
Old 05-30-2010, 08:04 PM   #7
joey's Avatar
Might help if we know what your are driving with this issue and mileage as well as any other maintenance beyond plugs and wires.
__________________
Joey
Cincinnati OH
http://www.customroveraccessories.com Home of the New D2 horn buttons!
13 Jaguar XF
1951 F2 - Flatbed
1946 D24 4D Custom
02 Disco - Sold
97 Disco - Out to pasture due to rusted frame
http://www.usarovers.com/ (call for Rover parts ask for Nathan 502-222-5859)
Rover Radio issues or IPOD Adapters http://home.valornet.com/splacket/index.htm
EAS fault http://www.rswsolutions.com
When working with GEMS vehicles. Never try to locate a misfire by pulling plug leads off - pull the injector connector instead. Otherwise you can blow up the ECU.
Secondly never swap ECUs between vehicles to test them, because both vehicles and ECUs may stop working, and you'll have to have them all reset by a franchised LR dealer (ouch!).
To download the RAVE manual, follow this link http://www.landroverresource.com/
joey is online now   Reply With Quote
Old 05-31-2010, 01:08 PM   #8
Chongo
Chongo's Avatar
Obd2
Thanks much,
Charles Harvey
Hello, To start off with your right, OBD2 was voted in by congress, so that all vehicles had a standard diagnostic tool, What they didn’t tell you is that it only covers emission systems only. Now other companies, US, Japanese etc may allow and have more systems accessible by OBD2 diagnostics, i.e. antilock airbag etc, most European auto manufacturers do not.
What this means to you as a European / British auto owner is that the software version of the Rover is completely different than the US version. For example: older OBDII protocols commonly used in vehicles: VPW (General Motors), PWM (Ford), and ISO9141 (Chrysler, Asian, European, and many others), and ISO 14230 protocol (also called Keyword 2000 or KWP 2000). CAN protocol language is for newer vehicle protocols only. This link below may help you even further, But due to marketing, ( Money ) different software’s are made to drive up the repair and diagnostic costs. Especially on more exotic types of vehicles.
http://en.wikipedia.org/wiki/On-board_diagnostics
Use the Rave Manual in Joey’s Footer notes, or click here:
Once you get the OBD2 code, you’ll find there is a difference usually between US OBD2 codes and European OBD2 code meanings:
http://en.wikipedia.org/wiki/Controller_area_network
From Atlantic British I purchased the Hawkeye diagnostic tool from them and I was amazed. They did their homework on this very user friendly, owner friendly diagnostic tool. It works on your vin number only, and cost an additional $250 per vehicle vin, or $1,500.00 if I remember correctly. It cost me around $650.00 delivered, and it does everything but program the processors. I own many Rover diagnostic tools, however this one proved to be most useful in Rover home mechanics market. Click link below:
http://www.roverparts.com/Nxt/search...ywords=hawkeye
Best wishes……………………………..Chongo
Chongo is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Sponsor Ads
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
Fully Driven Auto Network
GM Truck Forum
Chevy Tahoe Forum
Dodge Ram Forum
Chevy Cobalt Forum
Chevy Tahoe Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Ford Raptor Forum
Scion FR-S Forum
Softball Forum
TRD Forum
Central US Mopars
Southeast Mopars
Cadillac CTS Forum
Oklahoma Dodge Ram Club
Softball Forum
