Recently our 08 LR3 HSE, 3 months out of warranty threw up a damn christmas tree display of warnings, lowered the suspension to the stops and was pretty much not driveable as a result.
Various readings on the Internet said, switch out the battery for a new one. So I stuck the battery on a charger, it seemed okay but I forked over the 150 bucks for a new one at the local auto parts store anyway.
No resolution, the issue continued. The next thing I read was to replace the brake switch (sometimes referred to as the stop light switch or sensor). 24 bucks from the local LR dealer, 2 minutes to swap it, disconnect the ground to clear the codes and viola, no more issue.
Should this issue occur for anyone else I would highly suggest you pull the brake switch, take it apart and look for evidence of electrical arcing -- black stuff around the contacts. If evidence of this is found, replacing it is cheap and easy with a newer unit from FOMOCO oddly made in Morocco.
Why you ask would a simple brake switch failure result in such a catastrophic overall failure of the car? No idea. British electrics and all I suppose.
