whiskeynipple
- Joined
- Apr 24, 2006
- Posts
- 97
- Reaction score
- 0
My mom has a D2 2000 w/ 8*k miles - stock
never had any issues other than new plug wires
the other day on the way to work the vehicle overheated (within a few min after starting - her comute is only 10 min and this was half way there)- as soon as the red light came on she pulled off the road and shut off the engine - (note: she also noticed no heat, as the heat was on)
pops the hood and theres steam coming out.
she put some water (about a quart) in it and continued to work (after leetting it cool)- the temp gauge started to creap up again (little past normal) and she pulled off and shut the engine off again, added more water and continued (yes she continued after the engine cooled back down-both times) after that the temp didnt rise above normal and heat was coming out of the vents
so a few days go by and it happens again - but not to the extent of the light coming on (meanwhile running like a champ) and the check engine light is on- she has it towed to the stealer (anyone know a good machinic in south carolina?) - they tell her (she told them not to do any work on it - ie I dont want to pay you **** till you know whats up) she needs a new engine.
I personally think how can they determine this without a lenthy investigation - ie compression check , pull the heads... etc....
I instructed her to have them explain how they determined this without chaging her any money? - will post those results when she finds out tomorrow
she said there is no smoke from the exhust and no water in the oil and it runs fine (of course she put normal radiator fluid back in).
I believe its the thermastat and hopefully no serious damage has occured.
question - where is the temp sensor located - engine block or radiator?
could one overheat toast the engine?
if no heat is coming from the vents - wouldnt that say thermastat?
how hard is it to change a thermastat on a 2000?
my poor mom still owes on the dam thing and shes freaking out
thanks
Chris
thanks
Chris
