LR4 Parking Sensors
brandon
I just got my 2010 LR4 home and found that none of the parking sensors are working. I checked each one for the clicking sound with no response. I get the sensor fault "beep" with the flashing light when I put it in reverse. It's still under warranty but the closest dealer is 80 miles away so I thought if there's a fuse or other quick check, I'd try that first. Any ideas???
brandon
update
The parking lines in for the reverse camera are also not displaying. I don't even have a "camera" icon on the home screen. Not sure if these two issues could be related???
brandon
Update:
Just got my LR4 back from the dealer. The backup camera had an internal fault and needs to be replaced. The two front parking sensors were removed when the previous owner had a winch installed which made the rear sensors inactive as well. The shop will need to reprogram the sensors to only look for the rear sensors which unfortunately isn't covered by the warranty.
Does anyone know if this reprogramming can be done outside the dealership?
jjvd21
Programming could be done by somebody with a faultmate. But I would have your dealer do the job. Shouldn't cost more than 30 mins of labor time.
stmcknig
Shouldn't but I usually find my dealer has a minimum one hour charge. They claim its because their laptops boot up so slowly to connect to the Rover ;-)
Izanagi
