Security Code
Alberta, Canada
Does anybody have away of finding a security code for 2001 HSE (Anniversary Model Range Rover ) the code I was given does not seem to work, thankyou
By security code you mean for the radio? If so, have you tried contacting a dealer? Proof of Ownership and VIN will normally get you the code. If the radio has been replaced not at the dealer, then you may have to remove the radio and use it's serial number to get the code.
Alberta, Canada
No not the radio, the alarm sounds every time I put the key in the ignition and it will not start. The side lights flash to accept the key when I unlock the car but the alarm light still flashes. Have tried unlocking and locking it several times, disconnected the battery in the hope it will reset, but put the battery in and same thing happens.
I take it the locking and unlocking of the doors didn't help?
sawcut
