As the rigs weigh the same, I wonder how quickly those things burn through the smaller brakes.
I thought it was bad enough on ours.
Oh Mr Surf, why do you say such things ?
My lr3 weighs a hell of a lot more than yours (7200-8400 lbs) with E load range 32" tires and I'm still using rotors from about 70,000 miles ago although they are finally due for removal. These are apparently brembo oem replacements that were put on around 50,000 miles. They rusted to be so ugly in the first few months but wow they sure have lasted.
Your brake wear is due to how YOU drive, not the vehicle weight. Even panic stops on mine are spot on as short as I can imagine ever needing with this thing.
I'm actually swapping to the v6 sized rotors for this next phase so that I don't have to use spacers with my 17's unless I choose to do so.
