[/QUOTE]My reservoir had a crack. I replaced it. When replacing I noticed the old reservoir did not have the coolant level wiring attached but instead had a piece of metal curved to go into the female parts of the wiring and close off/ground the wiring to not be attached to the reservoir.
I attached it to the new one and it says low coolant level when the coolant level is correct. Being it is a brand new reservoir, I assume this means the wiring is bad and I need to replace it or ground out that wiring and just not have it attached?
