jwest
Thanks for heads up. I ended up spraying with silicone as I do with most non metal stuff. Thankfully that one is ok. I guess petroleum based products can cause rapid break down of poly. I ended up replacing the links with the MOOG problem solver and my problem went away. Seems good quality in comparison to the other I had on (I think beck/arnley)
Is this the first time you've had to do the front control arms? My lower we're toast at 60k and have about 20k on the reworked ones.
At 130,000 miles, all my stuff is original.
