BFG KO2 275/70 18 too big?
TheWire
I have a friend that has a set of KO2s that are 275/70 18 that he is willing to give away to me for a steal. My first thought was that they were too big. Anyone else running that size or am I asking for problems? I have 275/65 18 Duratracs right now that work great size wise.
If you're running 275/65s then I think you already know the answer....it's been done but it isn't adviseable.
jwest
Seattle WA
Lol if you haven’t made the fender liner, rear wheel well housing body flange and hvac limes relocation, then the 32 don’t really fit either.
The problem is you’d be stuck for sure if ever lose the air. Also 33” highly likely tu run everywhere up front and spacers only make that worse. A lot more work is required for 33”
daaniel
orange country
I'm running 275/65/18 ko2s. they do rub a little in the front and a bit in the rear as well nothing crazy tho. I also have the Jonson rods installed. so that helps.
gabrielef
NorCal
How’d this work out for you? Have you thought of raising the stock suspension height using a JR’s or perhaps using software? I’m about to put KO2’s on mine.
Izanagi
