02
thanks for the thorough replies.
Honestly I only had this car for a short while so I haven't done anything to it. The air filter looks fairly new.
I have been told not to clean the MAF sensor as it could damage it. Is this true?
If not what can I use to clean it.
Also I am trying to just change what I need to for now so do you think its safe just to change the front drivers side O2 as thats the one that looks to be the culprit?
I am gonna also try some new gas and fuel injector cleaner and see if that helps.
To clean the maf sensor all you need is a fast evaporating solvent like lacquer thinner or m.e.k. or something similar. They offer it in spray cans, I use to use brakekleen but the changed the product almost ten years ago here in cali. The parts store you go to should be able to know of a product they sell for this task. The 02 could be the culprit. Not being there no one can be 100% sure, but it is a good step in the elimination process. It could be electrical issues. But the 130 code is most likely a 02 sensor. Check the fuses and the connectors before buying a new one.
Good luck…….. chongo
