Alarm just going off intermittantly, doors lock.
fredseuro
Morgan Hill, Ca
using out Snap on scanner and also Autologic. Did full scan. Can't talk to TPMS module (tire pressure)
Zero codes setting in Body module. Live values everything is off except the "Tilt" sensor, saying on?
Anyone seen this?
Customer has two complaint, tire warning light on and Alarm just going off.
Tire warning light, could be a bad sensor at the wheel...
Alarm going off check the hood sensor
london903
I had the same problem with my 2009 Range Rover Sport. Changed the Hood Sensor, problem went away.
TX300WinMag
Texas
2008 LR2 same thing replaced hood latch sensor. Issue solved easiest and cheapest fix so far!!
rally3
Sacramento ca
Anyone seen this?
Most likely bonnet latch for alarm,
if it is a 07-09 sport then the tpms issue is most likely a failed tpms ecu
Redinak
Anyone seen this?
I had an alarm issue so I disabled the hood sensor....lol no more alarm issues.
Sent from my SAMSUNG-SM-G900A using Tapatalk
A562NV
