hollygcape
Alright, so I have a 2005 Land Rover LR3 V8, 110k miles. About a month ago the car completely dropped, started throwing an amber suspension light, bounced all over the place so we took it to a local dealer, apparently it was the compressor and a small air leak. Both were fixed. On our way to the dealer the radiator blew (just our luck), so the car was towed and that was also replaced. About a week later the car started overheating (again, my our luck), leaking coolant, and throwing the amber suspension light again. Turned out to be the water pump gasket, that was replaced. Once the water pump was fixed, not even 2 days later the LR3 started throwing a RED suspension fault: do not exceed 30 mph. That next day the front dropped and the back stayed raised. Now when you start the car an amber suspension light immediately comes on. Once you hit 25 mph it throws a red suspension fault: do not exceed 30 mph. We checked over the LR3 ourselves and found that the front valve block was broken. We replaced it. The car then raised to normal height, acted fine for about 10 minutes and then threw an amber suspension light. Not even 30 minutes later the front sank back down. The car is obviously unstable due to the back being over raised and the front not raising at all. It's bouncing again, I assume that's also because it's unstable. Trying to wrap my head around what else it could possibly be. It isn't showing any codes and the 4x4 info menu isn't showing that a sensor is out. The only thing I can think of is another air leak or an air bag. HELP ME FIGURE THIS OUT! I have googled my life away and can't find where any one else has had this problem or similar.
