Battery Life
NeilP
I buy a new battery every 3 years . Just installed the second replacement in a 2007 4.4 HSE LR3
Every replacement is a little more power and a lot less cost too . These 800cca-class batteries
are becoming more common place , so they're easier to get at no notice . No need for Varta
originals anymore .
gsxr
Idaho
Sounds like I'm the only one, but I've not had good experiences with Interstate batteries. I've had at least four, possibly five, Interstate battery failures over the past 10 years in different vehicles. All the failures were due to a shorted cell - this causes the battery to show normal/full voltage with light load, but voltage drops to low single digits with any serious load (i.e., starter engaged). All the failed Interstates were wet-cell flooded (not AGM), all were Group 48 or 49 (or equivalent, like the 93), and IIRC all were roughly 3-4 years old.
I've been buying only AGM batteries now; I have a couple of factory/dealer Mercedes AGM Group 49's that are 12 and 14 years old respectively, and still going strong. (Those are trunk-mounted away from engine heat, which probably helps longevity.) AGM's cost more up front but IMO tend to have better reliability, lifespan, and I like the safety aspect with no concern about leakage or explosion hazard. When the current battery in my LR4 finally dies I'll be looking for a Group 49 AGM to replace it.
Related anecdote: I have a PowerPulse desulfator installed in a number of my vehicles, with both standard flooded and AGM batteries. Most all of them have been seeing 10+ year battery life. Click here for more info. Now that batteries are $150-$200 for AGM, if a $40 desulfator can extend the life a few years, IMO it's worth it. Be warned that the PowerPulse uses some battery power to function, if the vehicle will be parked for more than 2-3 weeks, you MUST put it on a trickle charger / maintainer or you may find a flat battery a month later. Even without a desulfator, a trickle charger is still a good idea if parking for 3+ weeks...
Bethesda, Maryland, USA
Evidently my dealer's warnings about AGM batteries in the LR4 are either purely technical and unlikely in real world applications, or just misinformed. They could also be unadulterated upsell BS, but I've never felt lied to there before in any way. Besides, if they were trying to upsell that's exactly what they would NOT be telling me. I know a lot of owners here have had good experiences with AGM batteries.
I'm going the AGM route for the next battery, whether this Interstate fails under warranty or not.
SHS14
What agm battery is everyone going with? Odyssey? Deca?
Exide Edge AGM L5/49/H8 here... Last time I checked, Odyssey didn't have a H8/49 size available. That would have been my first choice otherwise.
Yup, that sure looks like a match. Lots of dough, but Odysseys should be worth the extra splurge.
Surfrider77
Bad luck. Yesterday was the first time my LR left me stranded here at work. Earlier in the morning, it fired right up as usual. No weird electric gremlins noticed on the drive in. Made it to work without issue. Went to go home and pressed the Start button and "thunk" and then nothing. Interior lights were struggling to stay on it was so bad.
I had jumper cables, but my buddie's tiny econobox didn't seem to give enough juice to turn the LR4 over, though the lights were functioning fine and charged it for 10+mins. I even disconnected my battery and left the jump lead directly connected to the truck leads. No dice, wouldn't turn over.
Left it overnight and it was so dead, the remote key fob wouldn't even unlock the doors. I had to manually crank it open with the physical key in the fob. Swapped out the battery with a new OEM one and it fired right up. Drove it straight to the dealer to get reprogrammed (auto-up windows stopped working, etc) and in for service.
This is my 2nd battery in 4.5 years of ownership.
jptruck
Micro-start would have cranked it right up. Ditch the jumper cables and get the XP-10. It takes up less space and can crank a dead-battery car no problem.
Surfrider77
I followed the thread on here with the XP-10. It looked promising, but them started seeing pictures of the batteries expanding to the point of warping the plastic casing. Because I live in the desert and it is regularly 120F outside and god only knows how hot inside the truck, I wouldn't want to risk it. This is literally the first time in 4.5 years of ownership that I would have needed it.
