Cruise control fuse
Mack1965
My cruise control main switch blows when I depress it. I've changed the fuse with the right fuse. And blows again any help would be greatly appriciated. Very frustrating .....
Check the vacuum pump to make sure it isn't shorted out.
Mack1965
Ok we're is it located at. First time working on this landrover
Just heard from a good friend, it is either the button itself of the fuse box...
If you have replaced the switch then more than likely the fuse box. Sadly the D2's are known for water getting into the fuse box and causing corrosion.
A562NV
