I hope I can explain this well.
This morning there was some ice on my LR3. When I turned the ignition on, auto sensor kicked in and wiper started moving. The problem was that the driver side wiper somehow was stuck while the passenger side wiper went full cycle.
I turned it off, took some ice off and started again. Now both are working fine but the driver side wiper is off angle - meaning the range of movement is moved toward bottom - meaning it stops a couple of inch below where it used to park.
Not being a mechanic, I am not sure how it even happened. I thought if one is stuck then the other wiper shouldn't have moved?
Anyway, my question to LR3 experts is..... Is it easy as just take the wiper arm off, change angle and put it back or something must have broken (since one wiper was moving and the other was not) and I should have dealer look at it?
Thanks for replies in advance.
- Brian
- Brian
