97 Land Rover Discovery, SD. 84,700 miles
Air Blower Fan not working with switch in any position 0 – 4. No heat, no A/C. When ignition key is turned, condenser fans start immediately. When engine is started, condenser fan continues to run even though no A/C buttons are pressed and blower switch at zero.
All relevant fuses check out OK. There is no 12V power at the blower motor connector plug with engine running, A/C button pressed, and fan speed on any setting 1 – 4. I don’t know where any appropriate relay might be located.
(Previous to this A/C problem, my Service Engine light had come on. I fixed this by gaining access to the RED relay behind the passenger side kick-panel, Peeled back the paper label to reveal the hole and insert a small screwdriver to short-circuit the exposed pins.)
Wondering if my A/C problem could’ve been caused by some mishap while struggling among the wires behind the kick-panel, I took another look. I see a loose white connector with three wires: black, brown, and white/green. Brown is hot wire, black is ground, reading 12 VDC across these terminals. I can find no empty slot to plug-in this loose connector. What is this? Where does it belong? With a 102 degree heatwave in Seattle, fresh ideas are greatly appreciated.
