not starting
Ofc.PD
Hey guys I have an 04 Discovery. Last week check engine light came on and it started running terrible. No power and drinking gas. I read on form 1st thing is to check fuses. I checked them under dash and pulled and put them back. Then I check them under the hood. Same thing pulled them and put them back 1 at a time. Now it wont start. I am not sure if maybe one of the black fuses under the hood maybe bad or not. Any ideas as I am stumped. The car does turn over it just does not start.
evansjoem
Actually ignore that fuel pump, check ignition coil
Ofc.PD
Would that make it not start right after pulling and replacing fuses under the hood? Do they just fail like that?
Lock and unlock the driver's door with the key 4 times in a row, then attempt to start. You may have disabled a security feature.
Ofc.PD
Did the door unlock thing, checked the wires it has a spark, and I replaced the crank position sensor. None worked. I even unplugged battery for 20 mins to clear codes. Any ideas I am out of ideas and I dont want to keep throwing money at it.
evansjoem
Is the check engine light on? Do u have a code reader?
Izanagi
