ON SALE Super Gaz Performance Shock & Spring Kits!!
atlanticbritish
ON SALE Super Gaz Performance Shock & Spring Kits!!!
REDUCED PRICE LIMITED TIME ONLY!!!!!!!!!!!!!!!!
These quality Suspension Kits features everything you need for a complete spring and shock overhaul including four Performance Super Gaz Shock Absorbers and four quality Performance Lifted Yellow Coil Springs.
Super Gaz Shock Absorbers provide both performance and value. They offer a vast improvement in ride quality and damping performance, especially if you're looking to put your Rover through the paces off-road. The durable twin-tube design provides an added layer of protection, with the outer tube protecting the inner rod tube from the off-road dings and scrapes that can seize-up single-tube shocks. They feature a 35mm bore tube filled with Fuchs shock absorber fluid, using the best seal available, single piece eye rings, polyurethane bush mounts and a very durable powder coated finish. Ideal for use with our Yellow Spring range, Old Man Emu or genuine Land Rover springs.
Performance Lifted Yellow Coil Springs are high quality, versatile and competitively priced - the right choice when replacing the old sagging original springs. Developed by one of the world’s top spring manufacturers, these high quality, yellow powder-coated springs have been designed with the needs of today's Land Rover owners in mind. As Land Rovers are often off-road or working vehicles as well as the family car, uprated springs must offer the ability to carry loads, handle off-road terrain and provide a good ride on road. The progressive front springs offer a compliant ride when lightly loaded, but firm-up as the load increases.
