- Joined
- Jun 28, 2004
- Posts
- 10,473
- Reaction score
- 181
The sensor is more a wire issue, it is the steering column. Also I would spend the $50 and have a Rover mechanic just plug in real fast to tell you the issue. It may just need the SRS light reset.
As far at the Service Engine light, that could be anything and you need to check the codes...
The ABS light well not sure how they handle it where you are, but in Ohio thankfully we don't have instpections, I pulled the 30 AMP fuse under the dash for ABS and pulled the light out of the dash on my '97 drove it that way for 10 years before I had to put the old beast down.
