basstard440
- Joined
- May 12, 2006
- Posts
- 180
- Reaction score
- 0
2000 disco 4.0 115k. I was wondering if this sounds like a stat problem. It started off like this, at full temp while running it blew the top hose off the top of the stat housing. I chalked it up to that I did something stupid like not tightening the clamp when I replaced it oh so many months ago. I then doubled up all of those clamps. Then I noticed a drop in fluid level. I could smell it but had no visuals on the leak. Figured it was residual af slowly burning off and I reblead the system thinking I missed it the first time. It dropped level again so I check the oil, nothing. pull the plugs nothing. ***! Bleed again and add dye. Ran it all day without a drop. the next day I noticed a puddle under the car and found that it is boiling out of the tank. but seemed to still be full to the line. After starting it i noticed a steady drip from the over flow. again thinking it was my error I bleed it again. One would think that I would know how to do this after owning this vehicle for more than 3/4 of its life. Today after 30 minutes of driving it popped the throttle housing return pipe which is a hose that was switch last year. The heater is blowing hot at idle and gets really hot when on the throttle and it seems to still be boiling over. some hoses are hot and some are really hot when at operating temp. The temp looks normal from the dash. Thanks in advance.
