Weak windshield washer spray
Ttweedy
Twin Cities
So has anyone had the issue with a weak washer spray. My assumption it's needing a new pump.
Thanks,
Todd
Ttweedy
Twin Cities
Thx, I checked the nozzles and they appeared to be clear. I rooted around with a pin and nothing.
Thoughts?
remember5
I would just start at the reservoir and try to trouble shoot from there. If you don't have a shop manual can see if I can upload the wiper section.
remember5
I'm sorry to took me so long to send this, I never think about it when I'm at home, attached is the overview, if you want a single component let me know, there are about 8 sections under windscreen washing system.
  • Description and Operation.pdf
  • Specifications.pdf
DPetty2994
DFW
Had a similar issue.
Ended up being my Resovoir was cracked, and simply had a small amount in the tank—so not enough fluid to prime/allow much pressure to build up.
Ttweedy
Twin Cities
Thx, mine will hold fluid no problem. It just arch's it to the bottom half of the windshield. When your driving it's no good at all.
DPetty2994
DFW
Try replacing the nozzles first.
Then--if that doesn't fix it--disconnect the tubing to one of the nozzles, and hook to a long tube from another car's nozzle(that you've disconnected)
Basically--you're using Car B's pump to test YOUR LR's nozzle.
If it squirts great--you know the pump is shot.
A562NV
