Didn't get Owners manual, need to know what a button does?
C
cdg
There is a single button to the left of the heating controls on a 4 button cluster.
It has a picture of what looks like a 2 converging lines with a skateboard over it.
What does this button do for me?
95Classic
I'm pretty sure that button is to turn on/off cruise control. I have a similar looking button in my rangie in the same location with that function.
G
GadgetRick
Yes
It certainly sounds as if you are describing the cruise control switch. I always thought that icon was strange.
The Rickster
C
crosstep
I has the same question yesterday and "MightyMax" informed me that it is for the cruise control. I tested it last night and that was it...strange icon!
C
cdg
Thanks All, makes sense, but now I fear my Cruise doesn't work, but will test it tonight.
B
B2zD2
It is the cruise controll on /off button the icon is the same as the one used for the autobahn or freeway symbol in Europe.
C
cdg
It makes sense, so I tried it, my cruise doesn't appear to work, is there another light on the dash that comes on when the cruise it set?
Jeff Discos
It's supposed to resemble a highway, not some howlie grinding some phat rails on a skateboard. Strange indeed.
I can't recall if there is a light or not...but for some reason I think their is. I'd check, but my vacuum lines need to be checked as well.
tmiller1
Could you post a pic of your dash area, being sure to include the steering wheel (particularly the right hand side of the steering wheel)?
B
B2zD2
You will also need to pull back on the + set button on the right side of the steering wheel in order to activate the cruise controll
A562NV
