magnumforc
- Joined
- Sep 22, 2013
- Posts
- 103
- Reaction score
- 12
Does anyone know of a simple way to allow power to be maintained at the 12 volt power points when the ignition/accessory switch is off? I know when you open the door and the interior lights go on that the power points are activated for a minute or so. Also that if you shut off the ignition and do not open the door they remain powered until you open the door (like the radio).
What I am trying to accomplish is having the power points remain active all the time so one or more emergency lights can be plugged in and remain lit without the ignition being on or the engine running. I do accident investigation and use the LR4 for some of those cass where it's not easy to get to the scene with an ordinary car. I need the lights to protect the vehicle from other people who might not otherwise see it, even off the road. The lights draw less than 1/2 amp each, so killing the battery is not an issue.
Thanks for any ideas.
