Folding mirrors while locking
Blkrover1111
North hollywood
Thanks guys it was alot of help it worked but only problem I had was when the file is being loaded to the car the blue bar stops short and after 10 or so minutes it says load incomplete but then when I exit out and go back the chance is in the list and as anyone had the same issue
Are you using Bluetooth, or the steering wheel buttons to make changes to the CCF? I have always used the steering wheel buttons when messing around / uploading the CCF, I just feel better taking the somewhat finicky Bluetooth connection out of the equation... I figured it's one less thing that could go wrong during that very, very critical upload process. ;) I have never experienced an "incomplete CCF upload" message like you did, but since the change you made apparently stuck, my guess is that your Bluetooth connection - not the file upload itself - got interrupted during one of the multiple resets / reboots the car's electronic went through as part of the routine.
mshale
Alabama
I get an incomplete load every time. Never had any issues though.
I was worried that the motors would give too. Mine is a secondhand ‘13 and they are still working fine.
pceresia
Ottawa, Ontario, Canada
A question about folding mirrors on my 2016 LR4. I would like to have the mirrors fold automatically when I shut off the engine. I have a two car garage which I can get the vehicle into easily enough with the mirrors extended; however, exiting the vehicle is a very tight squeeze. Right now my only option is too manually fold the mirrors. Is there a way too have the mirrors automatically fold when the vehicle is shut off and unfold when it is turned on?
A562NV
