quirozson
Have a creak-squawk in my suspension that is periodic. Only happens at slow speeds going over small bumps. I can also replicate the sound when pumping brakes at a stop light; sound is a bit different.
Pushed on the suspension in my garage and couldn't replicate. Jacked up the car and inspected all bushings I could leverage with a pry bar. Nothing seems to wiggle easily; a bit of play in the front control arm rear bushing (bigger one); seems normal.
Lower bushings on sway bar link look like they have some sag. This is where I'm leaning, bit there is no play in the bushings when I tried to apply force using a pry bar. Couldn't find any movement in the sway bar either.
I'm sure some experienced techs have seen this before. Ideas? How do I diagnose? 2011 LR4.
Thanks.
Thanks.
