TrinidadLR4
Hello all. I have 83k on my 2013 HSE and am getting ready to do the LCAs(both bushings on each side + ball joints). I also bought sway bar bushings and sway links(although not sure if they are worn or not, just seemed prudent). Is there anything else up front that's worth replacing at the same time that has a limited lifespan much like the LCAs? Tie rod ends? Any other bushings or links worth knocking out at <100k to save time later? Thanks!
