Headlight Replacement Question LR2 2014
Tommilousis
Toronto
My right headlight is out. The low beam and high beam. Fog light still works.
Do I have to buy the H7 and H11 bulbs?
H7 says highbeam and H11 low beam, but when I remove the casing, I only see one socket for the headlight and one for the fog light. Am I missing something?
Please help!
Phill
Sweden
Fog lights are not in the headlight cluster, do you have xenon bulbs. Not sure about the American set up but on my European f2 the headlight cluster contains, sidelight, low beam and xenon high beam. It would be strange for both high and low beam to go wrong at the same time. Have you checked the fuses
Tommilousis
Toronto
No worries, I have found it, it's F9 in the fuse cluster found in the glove box. However, what does the column 'A' stand for? Its value is 15. Is that ampage?
Phill
Sweden
yes that is the amps, check to see it has blown, sry about the delay in replying was working yesterday.
Tommilousis
Toronto
Not a problem. I finally figured it out. It is in fact the H11 bulb and not the fuse. I've ordered the Phillips VisionPlus and know how to change it now. Thanks for your help.
