morrisdl
Wow they are 25% cheaper than anything else I have seen. I too am curious how they hold up to the weight of an LR3
Wow! Really.....their tread pattern looks just like the Fierce Attitude tires (a Goodyear venture).
Okay after looking closer, not really....the side lugs a little bit.
ilikeit
Portland, OR
First post, first Rover.
2006 HSE HD with 133k. Looking forward to learning about all of its issues.
Sent from my Pixel 3 using Tapatalk
You should head to the Tillamook State Forest and run the Powerline Trail IMMEDIATELY. :)
You'll learn all you need to know.
rfh1987
Looks like some nice, aggressive tires came with your new purchase. Nice! Love that color! I had an 06 that sprung a coolant leak while on a trail. $200 tow for a $10 part that the mechanics don't even use. It was the plastic bleed valve that's in the coolant line. The constant hot/cold and banging in the engine bay had made it brittle and shatter. Do yourself a favor and get that replaced with a metal piece that doesn't have the bleed valve, next time you bring it in (there's probably a much less wordy term for what I just described). Costs $10, and saves a headache.
Izanagi
