08 LR2 rear strut removal/replacement/ need help...
A Aron
USA
Hey to all of you rover folks.
This is for an 08 lr2 with 205k miles.
I have a blown right rear strut.
I have parts on way to replace both rears...any guidance available to do this?
I would like to buy a manual if available...
thanks!
Phill
Sweden
Just make sure you disconnect the abs sensor before you remove the strut, fairly straight forward job to remove the strut, make sure you mark up everything to replace in the same position, might think about new rubber cushion/ bottom pad for springs, they can get messed up when removing springs to replace strut.
Izanagi
