Good morning all,
When the pump is running there will be a certain amount of heat soak into the fluid surrounding it, together with the cooling effect of the fluid passing through the pump and into the fuel system. In our case the fluid is petrol, or gasoline.
The gasoline is the cooling medium for the pump.
After a period of operation the temperature will rise, it's not a question of how long the gasoline has been in the tank but how long the pump has been in operation. This temperature rise is affected by the amount of gas in the tank and the load on the pump, governed by the fuel demand of the engine.
more gasoline = cooler pump
less gasoline = warmer pump
Now how much of a difference in temperature in the real world does this make? Be my guest and pick a number.
Bottom line, don't run the tank into the reserve / down to empty, and you should preserve the life of the fuel pump.
Ok, I'll get off my soapbox now.
Be safe and keep your tank full, you never know when you may need it
Stu.
