Engine will not turn over
Two bears
Dallas Oregon
’06 LR3 160,000 mi( runs strong) i back it up in driveway, w/flashers on, ( i did not use it , over wkend, monday morning , i tried to start it, nothing , used my jump start tool nothing, only thing odd is flasher are on & i couldn’t turn them off, using switch? I believe engine may be immobilized ( i slow charged battery) i live in rural area w/ no Land Rover specialist.
What was the voltage shown on your slow-charger?
5crows
Lake Wisconsin, Wisconsin USA
Sure it's in Park or Neutral? Seems to me I had to step on the brake pedal and move the shift lever through the range of Park to Drive and Back, to get it to fire or something like that on a similar problem.
Too many cars, too many features.
It could be that the linkage system display on the dash is not synchronized with the shift lever P,R,N,D position. If the dash light does not have a P lit when you are in Park, it's a no start silence.
Sometimes going thru the gears will be enough to get it in sync and lit back up. Crawling under to check linkage, I found a switch above and in back of the linkage lever, that seemed worn, dirty and loose, when fiddled with, I got its connection going.
I also read, dealing with dead battery recovery, you might need to remove both cables from the battery posts and then arc between the positive and negative 'cable' ends with a single jumper cable wire to discharge the system, then reconnect positive and negative cables to posts. However, someone smarter then me should verify that scheme. I don't think I tried it, because of the linkage switch issue fixing my problem.
Sogs
Hope you fixed the damn thing, if not ask your friend to drive it into the river, I'm about ready to with mine. Nearest dealership/cert mechanic is 325 miles away around here also
ManontheMove
About 4 days ago We had a similar issue. Check battery connects, jumped battery, the whole nine. Went out and bought a new battery, nothing happened. Out of frustration I banged on the top of the fuse box
,hit the key and the engine fired up. I don't know what happened. Best guess. Relays and fuses in the fuse box may have some corrosion at the connection points, but I really don't know. No starting problems to this day.
remember5
Here are the manual files for the anti theft system, maybe they will help diagnose. Let me know if you need others.
  • Antenna Removal.pdf
  • Anti-Theft Alarm Horn with Battery Removal.pdf
  • Description and Operation.pdf
  • Hood Switch Removal.pdf
  • Specifications.pdf
remember5
This is the overall description.
OnoA
