I was thinking you had welders in your shop or garage only requiring rolling out then welding your project. I got fed up over 40 years ago bugging friends with welders, played stepping stone upgrading until the Miller 350 Synchrowave Tig and Miller 251 Mig machine w/30A Spoolgun suited my needs. Plasma cutter replacing O/A cutting as well welding. Being independent never relying on using others equipment, paying for machining, fabricating and welding projects. DIY is rewarding plus cost saving. Personal home use equipment, Sun Investigator smog machine, Hunter G111 4 wheel alignment machine, working on a Hunter wheel balancing machine. Keeping the LR running 20 years without any stealership.....~~=o&o>.....
