Fault code P010B-00 (E8)
Parker Freeland
Denver, CO
Greetings, I got a CEL and the GAP tool says the fault code is P010B-00 (E8). Mass or volume air flow B circuit – range/performance.
I tried to clear the fault but I gut an error message saying it could not update?
Ideas? Which side is the B circuit?
Parker Freeland
Denver, CO
After spraying both MAF sensors with MAF sensor cleaner I was able to clear the code!
Land Rover Owners
Proud and Paranoid!!
DaytonaRS7
looking at your intake, there is a sensor on the top of it (both driver and passenger side), close to the airbox. remove sensor, spray with MAF cleaner, reinstall. some people also have luck using electric contract cleaner, if you happen to have that handy.
Slowpoke13
San Diego
Really is that easy? Lol. Sounds good. And any ol’ can of MAF cleaner from the auto store will work (CRC, etc.)?
And I read just 10-15 squirts, no scrubbing. Let dry, then reinstall?
DaytonaRS7
correct. do not scrub. the sensors are fragile. let air dry.
CRC is my preferred electrical/MAf cleaner brand.
