jlglr4
I had my supercharger off for preventative maintenance on the cooling system and decided to replace the supercharger coupler. This a 2016 model year with just over 50K. The supercharger pulley had about 3-5 degrees of free play (before spring tension catches in forward or reverse). It was making a little noise - not too bad. The isolator didn’t look too bad either, but the spring was surprisingly loose in the body of the coupler. I couldn’t tell if this was as designed or not - nothing seemed to be broken or badly worn, but it sure didn’t look right to me. See pics. Slight grooving in the shaft, but not too bad.
The replacement itself is super simple if you’ve got the supercharger off for other reasons. Remove bolts (including one inside the throttlebody) and pry the snout off from the pry point on the drivers side of the supercharger (remove the manifold on that side to get a good purchase on the pry point). Old coupler slides off, and new one slides on. Used the Eaton brand solid coupler. Seal it back up with a very small bead of RTV.
But, at 50K (at least on mine), I don’t think this was bad enough to warrant a separate repair.
