Enabling features with IIDTool
Jimmy Brooks
Pasadena California
Need advice, I’m looking at iid tools too, one issue I’m having is pricing. I want a tool that I’m able to disable tpms and also probably change the suspense by an inch or 2 so it looks better with the big tires. Before you ask I’m not a very big fan of lift rods and don’t prefer to use them. There is such a price difference from 500- 2100. Is there anything in between I could use or to do minor changes with disabling and enabling and avoid the full $2100 cost. Need to replace my ac compressor as of now and trying to save money. Is there something I’m missing or did any of you get discounts?
Jose Aguilar
Mexico City
I'll make a tutorial tomorrow for you guys if you'd like.
Besides DRL what else would you guys want?
I'm 99% sure the mirror dip won't work without memory seats. (Module + controls)
HI. Did you managed to prepare the tutorials? Are they available?
CRYA
Napa Valley
Does anyone know how to disable TPMS on 2011 HSE?
Yep, I just did this yesterday. There were three parameters needing to be changed. Spare tire, Tire Pressure Monitoring 1 and Tire Pressure Monitoring 2. I missed one the first time and got a fault. Went back in, saw the one I missed in haste, and fixed it. All good now. It's under BCM-Body Control Module. The list comes up alphabetical I think, so scroll down to the the TPMS options and make your changes. Follow the prompts. It's almost foolproof....almost.
mmbirtcher
Thanks! Seems to have worked.
Now if I can get the HD radio working again….
SantaAna7
Greenville, SC
If you add full size spare with tpms does it need to be added with the IID or will the car notice it automatically?
Plan on adding it next week when I have new tires installed. Going to rotate all of them.
CRYA
Napa Valley
I'd guess that if your original equipment did not include a full-size spare with TPMS, then you'd need to change that to using the tool. You'll find the parameter for the spare listed separately on your tool.
SantaAna7
Greenville, SC
Thanks. Time to buy one.
sawcut
