Michael Gain
I was able to dedicate about and hour today (it is Christmas Eve afterall).
Because I did not provide a good picture the first time, here is the wire with the two spade terminals that goes into the smaller, two-wire connector (not to best, as the garage door was closed to conserve heat):
I then wrapped it pretty well in electrical tape to protect the circuit from the elements, and to add some stability.
I also started building the multi-pin connector harness:
All of the terminal ends are color coded by the stripe in each wire (i.e. blue with white stripe has white electrical tape):
Finally, here is a picture of the harness connected and the wire run up on top of the radiator cowl:
More fun to follow after Christmas.
Merry Christmas everyone!
