I keep a crowbar in mine.Now don't ask me how to get it out. I haven't tried that yet. I've only got around 4k miles on my set, so no rotation yet.
Is there benefit or downside in stepping down to 18 wheels and tires for primarily on road daily commuting? Thinking about Evo Coarse .. mostly because I love the design . LR4 Will probably evolve into overland vehicle later on down the line but for now it’s my daily.
Evo Corse DakarZero 18"x8.5" Land Rover LR4 5x120 ET:35
Details - Size: width 8.5”, diameter 18”.- Material: Aluminium A356 alloy with heat treatment T6 and low pressure cast in steel permanent mould. - Load Rating: 1,300kg per wheel.- Nut fixing: steel insert.- Color: silver, gold, anthracite, and matte black.- Coupled spokes design in order to...www.mainlineoverland.com
About a half inch on each side.Hi all! I need to know whether BFGs 265/65-18 on Compomotive rims result in a larger track width (in an LR4) than the factory 255/55-19 (OEM rims). No other mods, spacers, etc. Anybody knows? I'm looking at buying property with a very narrow garage access driveway (tall curbs, the walls are not a problem) and even an extra inch on each side would complicate matters.
Thanks a million, @hickersb, that should still be possible, although I'd need to become master driver there.About a half inch on each side.
Gonna be close. Stock 19 is offset ET53, Compos are ET44? I believe. So 1/2 the difference. Tires are also about 10mm wider. So you’re moving the outside edge 14-15 mm further out on each side.
