Frozen Radio Screen
Northern Rover
Grande Prairie, AB, Canada
Can you repost the TSB? Our 2012 LR4's radio/nav/camera all started acting very weird yesterday and is persisting today. Bluetooth won't connect, no backup camera, switching stations on its own, won't respond to inputs on the screen...
I was Hoping to get this thread going again as i'm experiencing these exact issues mentioned by righg
We're you able to figure this out?
i've tried dissconnecting the battery, connecting the terminals and such with no luck.
Any info would be great
DallasLoneStar
Dallas, TX
Having this issue as well, and was hoping some others have had more experience in the past 7 years. Logo on screen, unresponsive to inputs when it does finally boot up, no backup camera on screen, etc.
richg
Thought it was a bad amp, but It ended up being a bad wire that supplied 12v to the amp. I had to splice in a new wire. Been fine ever since.
richg
The amp is on the passenger side in the cargo area.
There are two fused +12V supplies to the amp.
Central Junction Box, F41, 5A, a yellow & red wire to the amp
Engine Junction Box, F69, 40A, a fat red wire to the amp
These feeds are on different plugs at the amp, the main power feed is the fat red wire, the "wake up" is the smaller yellow & red wire.
With the truck on, you should see 12-14V at the connector for each of these wires. On my truck, I was only measuring .7V on the yellow/red wire (so the amp would not turn on). So somewhere between the central junction box and the amp, something went bad.
My fix was to make a jumper from the 12V signal on the sat radio over to the yellow/red wire at the amp connector (cut the yellow/red wire, isolate the end that heads back to the CJB so you don't risk causing a future short, then connect your jumper to the end still attached to the connector). With it like this, the amp turn-on is now running off the sat radio fuse, but I haven't had an issue for the 5 years I've been running like this.
Rich
The easiest potential fix--and one that I would try first--is to disconnect the battery for a few minutes and then reconnect.
I had a freezing issue with my head unit back in 2017 or so that was rectified by the "Land Rover Reset" I just identified. It could be caused by something more sinister, but it's worth trying.
A562NV
