06 LR3 suspension issue
remember5
You are probably corr
This doesn't sound like a short or a fault to me. It was a momentary engagement in a turn, which is exactly when DSC should activate, but it's usually not happening in routine turns at what I assume are normal speeds and conditions. That's why I think it's related to something loose in the suspension. It's been reported over the years.
You are probably correct. I just always think electrical since I keep the mechanical componets up to ***** and replace them periodically.
DoctaX
I also replaced all wheel speed sensors and was wondering if one or more could be defective and triggering the aberrant braking and delayed suspension fault????
That could absolutely be at fault. No pun intended.
petrhick
