What should I strip off this LR3 for spare parts for my LR4?
LR4Slavo
Denver
This 2006 Beauty just showed up at my local U-Pull junk yard this evening - anything worth while to pull for spare parts?
Surprised this thing is at a junk yard, seems to be in great shape cosmetically.
f1racer328
AZ
Are those the 18" wheels? Probably worth while if you off road.
Any idea why it made it into a junk yard? The 4.4 V8s are supposed to be pretty reliable. I've been eyeing up LR3s as another vehicle, but with fuel going up I'm not sure I want two bricks in my garage.
Bethesda, Maryland, USA
Looks like it has an aftermarket hitch. I wonder if the hood latch sensor and brake switch would be worth picking. You are right, the exterior looks great.
LR4Slavo
Denver
Good call on the wheels! I was thinking the same about the hitch and possibly the wiring harness, I'll try to stop by today before those goodies get picked.
jjvd21
Tailgate actuator motor, rear wiper motor, air suspension reservoir, spare wheel winch mechanism, wheel bearings
NorthwestDriver
Seattle
Wheel arch trim--fender flares. Matte black is better than body color IMO.
Those flares won’t fit an LR4 without swapping the fenders, headlights, and front bumper.
I’d grab air valve blocks, ride height sensors (if cheap), roof rails (if needed), wheels (if they will sell them, some won’t for whatever reason). The air compressor could be good for a spare if you have a hitachi (I think they changed to AMK in 2012).
Honestly, there isn’t a lot that is interchangeable beyond the glass and parts of the suspension. I think the transfer case in early LR4s is identical, but that’s an ordeal to remove and I wouldn’t want to do it at a U-Pull.
Michael Gain
Clarksville, TN
They will fit just fine. It's been done
Here is the member on here if you want to message him
Post in thread 'Front Fender Flare' https://www.landroverworld.org/threads/front-fender-flare.41517/post-213662
Nothing would **** me off more than doing all the work to change out a mechanical part only to find the part I replaced it with is 90% clapped out. Maybe I'm showing my privilege or something, but I'd stick with pulling hard, non-mechanical parts like wheels, roof rails, fender flares, etc.
No telling how many miles the compressor, valves, springs, etc. have on them. Only way I'd ever use a part like that is if I was looking to flip my Rover shortly, and I might even have a moral problem with that unless I'm totally resurrecting a basket case.
Izanagi
