distractedad
Hello from Louisiana! 2006 LR3 164k miles. So the struts and pump (amk) replaced in 2014. Here's what happened. I parked it for a couple days ended up with a flat tire from a screw. Jacked up the back right to plug and air up the tire easier. I started the vehicle to run the 12v air pump for tire at that moment the suspension went flat to bump stops at this time I had Johnson rods installed. Haven't been able to get it back since It was showing faulty height sensors at local dealership when I had code read. So I replaced all 4 of them even replaced stock height sensor arms. I thought it might be valve block or pressure sensor. I replaced middle valve block. I think the system might have a leak before because the air pump did come on almost every time I started it. Any help is appreciated! Here are the codes Im getting on iid tool ... The air pump does come on and then I get fault immediately . Could this be a cross articulation or miss calibration of the height sensors? I feel like the answer is simple I'm just not familiar with land Rover at all.
