Disco L319 engine swap for 3.6 V8 diesel
nuke
Romania
Hi,
I have a small shop mainly doing engine and transmission service on L320, L319, L322,L405
Recently a client call for the crankshaft failure with a Disco L319 2012 3.0 TDV6 with an ''unusual'' :))
request to do for him a retrofit with 3.6 TDV8 instead of replacing the broken TDV6.
I,ve did some research and looks like on the previous generation of L319 /L320 the retrofit from 2.7TDV6 to 3.6TDV8 can be done thanks to Siemens ECU mainframe.
Anyone can help me regarding the second generation Bosch ECU mainframe after 2010 and so on in order to retrofit the
Disco 3.0 TDV6 with 3.6 TDV8 engine?
Scanachi
Ohio
Hey there!
Welcome to the group.
I don’t have any insight regarding your question, butbI’d imagine @joey can share some values thoughts on the matter.
Cheers!
I sadly do not no much around engine swaps. I try to keep things as stock as possible. After going down this rabbit hole before, I find that swaps tend to cause all kinds of other fun, mostly around computers and how they interact.
A562NV
