maintenance history since new 2013
Lets see. I bought my 2010 LR4 usued in May 2013. So 9 1/2 years of ownership:
current mileage 201500 kms (125.6k miles)
I have put 127500kms on it (79.7k miles)
All maintenance (fluids,parts,tires windshields etc) = $13643 Cdn = $9960 USD
cost of maintenance $0.107/km CDN = $0.125 USD per mile
Your cost of $30000/ 137 000 miles = $0.219 USD per mile ! Whatcha been doing? Servicing at the dealer ? lol
ttforcefed
Around nyc independent service rates are $180 an hour. My number also includes the timing chain which is $7k
Fair enough. I turn wrenches on most of my stuff (outside of the LCAs). I have not done the timing chain so that will catch me up in a hurry if and when it ever gets done. If it does not sure dumping $7k into a $12k vehicle will be worth it. I anticipate that once I bite the bullet on chains it will have to be a DIY side project at home.
ttforcefed
150k miles
ttforcefed
my replaced Y pipe from 2018 (car has 75k miles, 150K now) just went. looks like they have an updated part now that shld be good for life, is that correct?
getting a bunch of work done here at 150k miles. will post once i get the final invoice. can you tell i hate new cars!?
ttforcefed
August 2023 150k miles $4,958
Battery dying/losing charge
Found coolant leak under intake manifold
Brakes worn less than 1/4 pad-Rotors warped
Removed complete intake manifold assembly
Removed and replaced oil cooler gasket set
Removed and replaced rear heater pipe/updated
Removed and replaced Y pipe manifold behind water pump
Removed and replaced alternator assembly
Removed and replaced battery + negative terminal W/Sensor
Removed and replaced front brakes (Pads + Rotors)
Removed and replaced rear brakes (Pads + Rotors)
Installed new brake pad wear sensors
Filled and bled coolant system
Reset ECU/Test drove vehicle
ttforcefed
entire history: $42k over 155K miles
DateMilesWorkPrice
4/1/2014
6,000​
oil200.00
9/30/201417,756oil, annual10.00
3/2/201523,345oil, pads/rotors all 41,225.00
9/19/201530,928oil211.00
8/8/201646,425oil195.00
4/13/201758,270radiator1,263.00
5/22/201760,473oil, 60k mile service, tranny, stf1,905.00
2/22/201871,836window switch548.00
4/26/201875,008oil, cig lighter fuse258.00
7/24/201879,062oil, 4 rotors/pads, differential, upper lower radiatior, water pipe etc3,800.00
12/4/201885,534right front heights sensor and strut2,067.00
1/2/201986,684oil, spark plugs, parking light968.00
1/7/201987,432control arm and shock1,535.00
6/17/201994,080Oil, EBC front and rear pads500.00
9/14/201997,500trunk actuator300.00
10/2/201998,580Running boards1,200.00
12/12/2019102,045oil change200.00
1/4/2020102,650right front sensor180.00
7/8/2020107,195oil150.00
11/16/2020111,892battery333.00
12/15/2020112,608oil, cabin filter737.00
6/15/2021117,960oil, front and rear pads, alignment2,200.00
8/20/2021121,000front and rear bumpers painted3,500.00
10/14/2021123,387oil, differential fluid, lower cntrl arm and joints, alignment2,284.00
2/24/2022126,035oil, timing chain, water pump, coolant system, belts, plugs7,593.00
6/12/2022132,473oil, AC service569.00
10/31/2022137,844oil, coolant, alignment800.00
11/29/2022140,508universal joint steering, tranny service1,291.00
3/3/2023145,008oil162.00
7/7/2023151,662oil162.00
8/11/2023152,000y pipe, alternator, battery, new pad sensors, front and rear brakes4,958.00
8/14/2023153,138fuel flange recall, fuel leak460.00
9/27/2023155,245oil162.00
41,926.00
